Not able to print through STLINK on cubeIDE serial Terminal (Not finding Serial Terminal on CubeIDE)
PShar.11
(Not getting Serial Terminal on CubeIDE)
KnarfB
You're right. The output used to be in the console window. But, I can open the serial port in a separate terminal prog (TeraTerm, PuTTY, minicom,...) and see the output. Actually, I like that debugging agnostic behaviour.
Pavel A.
That's the Eclipse ... :(
In a Console, click on NEW icon on its menu bar -> Command Shell console -> Conection type: Serial port.
-- pa
