(new) ST-Link V3 minie not working on Windows ( 7 or 10) ! Whats wrong ?
AScha.3
Chief II
new (from mouser) STLINK V3 MINIE not working on Windows PC (win7) , no driver found !
hey, on same PC STLINK V3MODS working without problem !
the brand new V3MINIE also on Win10 doing nothing - no error, no enumeration.
on win7 here :
no driver found.
_legacyfs_online_stmicro_images_0693W00000bkHFwQAM.pngand compare on USB V3mods right and V3minie left side:
_legacyfs_online_stmicro_images_0693W00000bkHGBQA2.pngdifferent PID .
what can i do now ?
 @peter BENSCH​  - any help ??
13 REPLIES 13
AScha.3
Chief II
ok, try on Win7 PC now update + change type :
_legacyfs_online_stmicro_images_0693W00000bkdj1QAA.png..device lost. new exciting gameplay...
then:
after upgrade try plug out and in to get new enumeration, but:
_legacyfs_online_stmicro_images_0693W00000bkdoFQAQ.pngthen, after some minutes (!!) - working.
_legacyfs_online_stmicro_images_0693W00000bkdooQAA.pngso:
  • download and install new win. drivers
  • update firmware + change type
  • wait some minutes...
thanks to all who have helped clarify ...
Have you connected the Vcc pin of MINIE to the target?
shure...
if you think about the 0,00V message : there was no target, just connect to St-Link was proofing connection.
problem was : need install driver (!) never need this before. new driver from STM needed.
and then update firmware / change type !
crazy...because the almost identical V3mods working instantly !
would you expect the almost same product from same company behave totally different ?
These days, you know, nothing is 100% sure.
Can be bad cables, power glitches... maybe a defective or damaged st-link too.
Try to swap all parts, use a good reliable machine. Win10 or 11.
