2026-04-27 1:02 AM - last edited on 2026-04-30 2:13 AM by KDJEM.1
Hi all,
I designed a custom STM32 board that powers up, but the firmware starts only after I manually press the reset button. Once reset is pressed, everything works normally.
The clock source is an external crystal, and BOOT pins are configured with resistors.
Questions:
2026-04-27 1:41 AM
What MCU part number you are using?
You should always provide the MCU part number when posting a question related to STM32.
2026-04-27 1:52 AM
As it's a custom board, you need to show its schematic - we have no other way to see it!
How to write your question to maximize your chances to find a solution
@eva_402 wrote:BOOT pins are configured with resistors.
How, exactly, are they configured?
Have you studied application note AN5673, Getting started with STM32C0 MCU hardware development ?
