Interrupts are not triggered during firmware-in-SRAM debugging using ST-Link
Stanley Lin
Posted on November 27, 2017 at 11:16
I have implemented my application firmware on STM32F746G discovery board and it worked fine while the code was located in embedded flash (just like most examples in cube).
Now I am trying to migrate code to SRAM using ST-Link, to evaluate the execution time between code in flash and RAM.
Current status is that the break points in main() could be reached, but the program was stalled in HAL_Delay() since the interrupt SysTick_Handler() was never triggered. I've spent all day long without finding any useful hint...
My environment is Keil uVision 5, and here is what I did to configure ST-Link debugging in SRAM:
  1. Change memory areas in Target tab
        IROM1: 0x20000000, 0x10000
        IRAM1: 0x20010000, 0x40000
  2. Add a define in C/C++ tab: VECT_TAB_SRAM
  3. Add debug init file (RAM.ini) and uncheck 'Load Application at Startup' in Debug tab
    FUNC void Setup (void) {
      SP = _RDWORD(0x20000000); // Setup Stack Pointer
      PC = _RDWORD(0x20000004); // Setup Program Counter
      XPSR = 0x01000000; // Set Thumb Bit
      _WDWORD(0xE000ED08, 0x20000000); // Setup Vector Table Offset Register
    LOAD %L INCREMENTAL // Download to RAM
    Setup();
    // g, main
  4. Uncheck 'Update Target before Debugging' in Utilities tab
  5. Press Settings button in Utilities tab, In Flash Download tab
    1. Download function: Do not erase
    2. RAM for Algorithm: 0x20010000, 0x1000
    3. Programming Algorithm: 20000000H - 2000FFFFH
Enclosed is a sample to describe my problem. Note that it's based on cube so it should be placed into the cube directory.
Thanks in advance.
#debug #stm32f7-discovery #st-link
Stanley Lin
Posted on December 29, 2017 at 10:45
I found the root cause from other thread:
https://community.st.com/0D50X00009bMM79SAG
If using CubeMX to generate a new project, there is no problem here.
But if using the project template in STM32F7Cube software, it needs to modify code in system_stm32f7xx.c:
#ifdef VECT_TAB_SRAM
SCB->VTOR = RAMDTCM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
#else
SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
#endif
Golab.Bogdan
‌'s help!
2 REPLIES 2
Stanley Lin
#else
#endif
Golab.Bogdan
‌'s help!
Posted on December 29, 2017 at 17:30
SCB->VTOR = &__Vectors; // would seem like a more bullet-proof method.
