Interfacing issue
JanhaviDeshpande
Help needed on interfacing buzzer with L476
4 REPLIES 4
Peter BENSCH
Welcome @JanhaviDeshpande, to the community!
Many details are still missing:
  • buzzer data sheet (link to the data sheet would be fine)
  • what supply voltage will the buzzer have
  • what frequencies should the buzzer emit and at what volume?
  • which waveforms should be sent to the buzzer?
  • are you planning to use an amplifier stage, if so, which one (or do you need proposals)?
/Peter
First of all, Thankyou Sir for replying to the message.
Basically, using TMB12A05 active buzzer for a project based on anamoly detection based on audio. Basic functioning includes giving alert.
Still not enough information on what you're trying to achieve.
  • "based on audio" - So do you have something that detects this audio? Microphone? Describe what this anomaly consists of.
  • The buzzer has a frequency range of 2300+/-300H. You need to have some kind of driver for it as well, which you haven't provided any schematic.
Tips and Tricks with TimerCallback https://www.youtube.com/@eebykarl
What's that?
As @Peter BENSCH said, give a link to its datasheet.
Please see the posting guidance on how get good replies to your questions:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
How To Interface Anything to Anything Else: http://www.8052mcu.com/forum/read/160143
