2024-10-13 11:19 PM
Greetings,
We are planning on using STM32H503KB MCU at 250MHz for our application. We have tested our code on NUCLEO board MB1814B which had an internal debugger IC STLINK-V3EC. For development what is the debugger tool that we should procure for easy flashing and debugging. Based on our research, we have found ST-LINK/V2 to be optimal for our solution.
Kindly provide us with your thoughts.
Thanks and regards,
Ravichandran. C
2024-10-14 5:16 AM
Yes ST-LINK/V2 will do.
But personally, I prefer working with SEGGER's J-Link which have better performances but is also more expensive.
S MARIE
2024-10-14 9:04 AM
You can also buy various versions of standalone ST-Link v3:
Overview of all the various ST-Link models:
2024-10-14 9:24 PM
Hi Marie,
Thank you for your input.
Ravichandran
2024-10-14 9:43 PM - edited 2024-10-14 9:44 PM
Hi Andrew,
I have looked at the products you have mentioned and have decided to go with ST-Link V2 since we only need SWD pins and ST-Link V3 have lot more functions and V2 is a bit cheaper compared to V3-Set.
Thanks and Regards,
Ravichandran
