I have a stlink v3set. mcu are stm32f723iek6. To me it is not possible to select mcu target.
Can you give to me an idea how to select apropriate target?
‎2023-01-17 1:02 PM
‎2023-01-18 2:53 AM
Hello @vVukm.1​
Could you further explain the issue please?
Are yo using STM32CubeMX or STM32CubeProgrammer ?
‎2023-01-19 1:16 PM
I'm using STM32CubeIDE and STM32CubeMX and CUBE STM32CubeProgrammer
and in any of this programs I 'cant select target STM32F723IEK6.
‎2023-01-19 5:53 PM
Reposting the same information doesn't advance the conversation.
Perhaps show STM32 Cube Programmer connecting with the ST-LINK/V3SET, and the STM32F723 MCU on *YOUR* board.
Are you talking about the STM32F723IEK6 that provides the ST-LINK functionality? Don't expect to be programming that.
‎2023-01-21 12:19 PM
I am only trying to write a simple program using STM32CubeIDE
connected with STLINK-V3SET.
When try to debug answer is:
Error in initializing ST-LINK device.
Reason: No device found on target.
Error message from debugger back end:
localhost:61234: Connection timed out.
Failed to execute MI command:
target remote localhost:61234
‎2023-01-21 12:47 PM
What is the ST-LINK/V3SET connected too?
The ST-LINK should be connecting to some STM32 device on a board you attach it too.
Diagram what you're doing
‎2023-01-22 10:55 AM
Hello @vVukm.1​,
It looks like your ST-LINK device is not being detected. There are a few things you can try to fix this issue:
- Make sure your board is properly connected to your computer and the ST-LINK device is securely attached to your board.
- Try different USB ports on your computer.
- Disconnect your board from power and USB, and reconnect them again.
- Connect under reset using STM32CubeProgrammer
- Did you try using a ST Link V2? as it is more stable.
- Check the ST-LINK configuration area and make sure the serial number is properly refreshed.
Also what board are you using exactly?
‎2023-01-24 12:25 PM
All of your suggestions are already done. But there are no
changes.
I have not used STLINK-V2.
Are there any possibility to activate my STM32F723IEK6?
‎2023-01-24 12:29 PM
you did not answer:
Diagram what you're doing !
what you want - if not show, what your doing ?
‎2023-01-25 10:37 AM
STLINK_V3SET is only connected to my Laptop.
I am trying to prepare some program to switch on/of LED
connected to GPIO on CN9 of MB1440.
