BFlin.1
How to use SNTP over LwIP and RTC with an STM32
  • November 11, 2024
  • 8 replies
  • 2268 views
Hello:
I have followed this exactly...
https://community.st.com/t5/stm32-mcus/how-to-use-sntp-over-lwip-and-rtc-with-an-stm32/ta-p/736706
I am using STM32CubeIDE V1.16.1 with a NUCLEO-H723ZG board.
There are no errors or warnings.
The code runns and I get...
SNTP Client
NUCLEO-H723ZG board
State: Ethernet Initialization ...
State: Looking for DHCP server ...
DHCP Timeout !!
Static IP address: 192.168.0.192
There is no red error light etc..
Can anyone help or perhaps B.Montanari ST Employee, (the author) etc. ?\
Thanks.
Andrew Neil
DHCP Timeout !!
So do you have a DHCP server on the network?
BFlin.1
BFlin.1Author
C:\Windows\SysWOW64>ipconfig /all | find /i "DHCP Server"
DHCP Server . . . . . . . . . . . : 10.0.0.1
Andrew Neil
That's the DHCP server that your PC is using.
What about your STM32 ?
Hello @BFlin.1 ,
Check your static IP address configurations. Make sure to enable the CPU DCache.
You can try this Nx_SNTP_Client example available in GitHub page and get inspired from this example to use it with Nucleo-H723ZG by following the instructions in the readme file.
BFlin.1
BFlin.1Author
Maybe please take a look at my set up for issues etc.
LCE
Principal II
November 12, 2024
So what's your setup, direct connection STM32 ETH to PC ethernet port?
As Andrew says, your STM32 cannot simply connect to some DHCP server via your PC.
Maybe you can find a PC app, or maybe your switch has a DHCP server function?
BFlin.1
BFlin.1Author
<So what's your setup, direct connection STM32 ETH to PC ethernet port?>
No, I am using straight cable to switch that goes to internet router.
LCE
Principal II
November 14, 2024
Then check if your router has a DHCP server that can be activated.
