2022-04-06 9:38 PM
I have a board based on the STM32L4R9 Discovery board. A key difference is that my board has Micron external flash (MT35XL512ABA1G12-0SIT) rather than Macronix (MX25LM51245GXDI0). The ST-LINK programmer fails to erase my flash, presumably because the OCTOSPI timings are different. It appears I have to build a custom external loader as I don't see one in https://github.com/STMicroelectronics/stm32-external-loader.
I am struggling to find the necessary timing data for the Micron flash. Has anyone done this already?
2023-02-08 12:22 AM
Yes I'm happy to, but I think the proper way is by pushing to a fork of the ST repo? If you can advise I'll find the code, give it a scrub and push it.
2023-02-08 2:26 AM
@OLync.1 Thank you for your reply.
Fork of the ST repo might take a longer time.
I need it urgently and if you can share your email then I will give my SharePoint access to you where you can push the source code.
