I am using STM32H743ZI and try to load program into it from uVision using ST LINK, but get the following error.
What could be the problem? Thank you.
‎2019-11-14 1:42 PM
Erase Done.
Programming Done.
Contents mismatch at: 08000360H (Flash=FFH Required=00H) !
Contents mismatch at: 08000361H (Flash=FFH Required=20H) !
Contents mismatch at: 08000362H (Flash=FFH Required=70H) !
Contents mismatch at: 08000363H (Flash=FFH Required=47H) !
Contents mismatch at: 08000364H (Flash=FFH Required=91H) !
Contents mismatch at: 08000365H (Flash=FFH Required=40H) !
Contents mismatch at: 08000366H (Flash=FFH Required=C2H) !
Contents mismatch at: 08000367H (Flash=FFH Required=F1H) !
Contents mismatch at: 08000368H (Flash=FFH Required=20H) !
Contents mismatch at: 08000369H (Flash=FFH Required=03H) !
Contents mismatch at: 0800036AH (Flash=FFH Required=20H) !
Contents mismatch at: 0800036BH (Flash=FFH Required=FAH) !
Contents mismatch at: 0800036CH (Flash=FFH Required=03H) !
Contents mismatch at: 0800036DH (Flash=FFH Required=F3H) !
Contents mismatch at: 0800036EH (Flash=FFH Required=19H) !
Contents mismatch at: 0800036FH (Flash=FFH Required=43H) !
Contents mismatch at: 08000370H (Flash=FFH Required=90H) !
Contents mismatch at: 08000371H (Flash=FFH Required=40H) !
Contents mismatch at: 08000372H (Flash=FFH Required=70H) !
Contents mismatch at: 08000373H (Flash=FFH Required=47H) !
Contents mismatch at: 08000374H (Flash=FFH Required=20H) !
Contents mismatch at: 08000375H (Flash=FFH Required=2AH) !
Contents mismatch at: 08000376H (Flash=FFH Required=04H) !
Contents mismatch at: 08000377H (Flash=FFH Required=DBH) !
Contents mismatch at: 08000378H (Flash=FFH Required=20H) !
Contents mismatch at: 08000379H (Flash=FFH Required=3AH) !
Contents mismatch at: 0800037AH (Flash=FFH Required=21H) !
Contents mismatch at: 0800037BH (Flash=FFH Required=FAH) !
Contents mismatch at: 0800037CH (Flash=FFH Required=02H) !
Contents mismatch at: 0800037DH (Flash=FFH Required=F0H) !
Contents mismatch at: 0800037EH (Flash=FFH Required=00H) !
Contents mismatch at: 0800037FH (Flash=FFH Required=21H) !
Contents mismatch at: 080003E0H (Flash=FFH Required=04H) !
Contents mismatch at: 080003E1H (Flash=FFH Required=46H) !
Contents mismatch at: 080003E2H (Flash=FFH Required=68H) !
Contents mismatch at: 080003E3H (Flash=FFH Required=68H) !
Contents mismatch at: 080003E4H (Flash=FFH Required=B0H) !
Contents mismatch at: 080003E5H (Flash=FFH Required=F5H) !
Contents mismatch at: 080003E6H (Flash=FFH Required=80H) !
Contents mismatch at: 080003E7H (Flash=FFH Required=3FH) !
Contents mismatch at: 080003E8H (Flash=FFH Required=06H) !
Contents mismatch at: 080003E9H (Flash=FFH Required=D0H) !
Contents mismatch at: 080003EAH (Flash=FFH Required=B0H) !
Contents mismatch at: 080003EBH (Flash=FFH Required=F5H) !
Contents mismatch at: 080003ECH (Flash=FFH Required=00H) !
Contents mismatch at: 080003EDH (Flash=FFH Required=3FH) !
Contents mismatch at: 080003EEH (Flash=FFH Required=03H) !
Contents mismatch at: 080003EFH (Flash=FFH Required=D0H) !
Contents mismatch at: 080003F0H (Flash=FFH Required=B0H) !
Contents mismatch at: 080003F1H (Flash=FFH Required=F5H) !
Contents mismatch at: 080003F2H (Flash=FFH Required=40H) !
Contents mismatch at: 080003F3H (Flash=FFH Required=3FH) !
Contents mismatch at: 080003F4H (Flash=FFH Required=26H) !
Contents mismatch at: 080003F5H (Flash=FFH Required=D1H) !
Contents mismatch at: 080003F6H (Flash=FFH Required=01H) !
Contents mismatch at: 080003F7H (Flash=FFH Required=E0H) !
Contents mismatch at: 080003F8H (Flash=FFH Required=00H) !
Contents mismatch at: 080003F9H (Flash=FFH Required=0CH) !
Contents mismatch at: 080003FAH (Flash=FFH Required=17H) !
Contents mismatch at: 080003FBH (Flash=FFH Required=E0H) !
Contents mismatch at: 080003FCH (Flash=FFH Required=A4H) !
Contents mismatch at: 080003FDH (Flash=FFH Required=08H) !
Contents mismatch at: 080003FEH (Flash=FFH Required=21H) !
Contents mismatch at: 080003FFH (Flash=FFH Required=E0H) !
Contents mismatch at: 08000740H (Flash=FFH Required=00H) !
Contents mismatch at: 08000741H (Flash=FFH Required=B0H) !
Contents mismatch at: 08000742H (Flash=FFH Required=5FH) !
Contents mismatch at: 08000743H (Flash=FFH Required=46H) !
Contents mismatch at: 08000744H (Flash=FFH Required=90H) !
Contents mismatch at: 08000745H (Flash=FFH Required=F8H) !
Contents mismatch at: 08000746H (Flash=FFH Required=50H) !
Contents mismatch at: 08000747H (Flash=FFH Required=00H) !
Contents mismatch at: 08000748H (Flash=FFH Required=DFH) !
Contents mismatch at: 08000749H (Flash=FFH Required=F8H) !
Contents mismatch at: 0800074AH (Flash=FFH Required=6CH) !
Contents mismatch at: 0800074BH (Flash=FFH Required=A3H) !
Contents mismatch at: 0800074CH (Flash=FFH Required=01H) !
Contents mismatch at: 0800074DH (Flash=FFH Required=28H) !
Contents mismatch at: 0800074EH (Flash=FFH Required=08H) !
Contents mismatch at: 0800074FH (Flash=FFH Required=D0H) !
Contents mismatch at: 08000750H (Flash=FFH Required=4FH) !
Contents mismatch at: 08000751H (Flash=FFH Required=F0H) !
Contents mismatch at: 08000752H (Flash=FFH Required=01H) !
Contents mismatch at: 08000753H (Flash=FFH Required=09H) !
Contents mismatch at: 08000754H (Flash=FFH Required=84H) !
Contents mismatch at: 08000755H (Flash=FFH Required=F8H) !
Contents mismatch at: 08000756H (Flash=FFH Required=50H) !
Contents mismatch at: 08000757H (Flash=FFH Required=90H) !
Contents mismatch at: 08000758H (Flash=FFH Required=20H) !
Contents mismatch at: 08000759H (Flash=FFH Required=68H) !
Contents mismatch at: 0800075AH (Flash=FFH Required=03H) !
Contents mismatch at: 0800075BH (Flash=FFH Required=F0H) !
Contents mismatch at: 0800075CH (Flash=FFH Required=9AH) !
Contents mismatch at: 0800075DH (Flash=FFH Required=FAH) !
Contents mismatch at: 0800075EH (Flash=FFH Required=18H) !
Contents mismatch at: 0800075FH (Flash=FFH Required=B1H) !
Contents mismatch at: 08000780H (Flash=FFH Required=09H) !
Contents mismatch at: 08000781H (Flash=FFH Required=FAH) !
Contents mismatch at: 08000782H (Flash=FFH Required=03H) !
Contents mismatch at: 08000783H (Flash=FFH Required=F0H) !
Too many errors to display !
Error: Flash Download failed - "Cortex-M7"
- Labels:
ST-Link
STM32H7 Series
‎2019-11-14 3:36 PM
Go into the Flash settings and switch between the H7 Single/Dual bank algorithm, and make sure the algo is for the 0x08000000 memory space.
What version of uV5? Current DLL and Firmware for the ST-LINK?
‎2019-11-14 3:50 PM
Thank you. Please see the following setting. What do you think is the problem?
‎2019-11-14 4:03 PM
‎2019-11-14 5:06 PM
I'd start by updating the ST-LINK firmware V2J35 is more current
https://www.st.com/en/development-tools/stsw-link007.html
