2024-07-15 4:38 AM
I have been looking for software that can take as an input, the PDM output from the MEMS microphone, and convert it to PCM.
I then want to implement a double buffer using DMA, to reduce CPU load and output the audio data to the DAC on this PCB.
Once I have this running I want to experiment with DSP, filters, delay lines etc...
If no software is available, does anyone know if a process is defined, with comments on why each element of the process is as it is for learning purposes?
Thanks in advance
2024-07-15 8:24 AM - edited 2024-07-15 8:25 AM
LMGTFY
AN5027: Interfacing pdm digital microphones using stm32
Also (specifically for the F4/F7, from Here)
https://www.st.com/en/embedded-software/x-cube-audio.html
https://www.st.com/en/embedded-software/x-cube-audio-kit.html
2024-07-15 11:20 AM
Thanks for that, but Im looking for something more basic for a beginner. Some sample code with process for learning purposes.
I'll certainly take a look at the links and do some head sratching....
