2021-06-09 10:37 AM
When i try to perform a full chip erase, i get the error: mass erase operation failed. please verify flash protection. I tried doing it sector by sector but get an error. I tried a few times and disconnected and reconnected my board. I'm not sure where to verify flash protection.
2021-06-09 10:46 AM
What chip? Show a screenshot of the option byte values.
What program are you using? STM32CubeProgrammer seems to work better most of the time, but ST-Link Utility can also work.
2021-06-09 10:57 AM - edited 2023-11-20 9:20 AM
I tried using both ST-Link Utility and STM32CubeProgrammer and get the same failing error on both.
2021-06-09 1:25 PM
So STM32G0, ST-LINK Utilites does look to be having issues reading the memory, not clear why.
Is this a board of your own construction?
2021-06-09 1:50 PM
Not real sure. Verify the target voltage matches what you expect.
2021-06-09 3:06 PM
No, this is the NUCLEO-GO71RB I obtained from ST
2021-06-09 3:17 PM
It does
