2024-03-12 01:51 AM
While trying to disable TZEN on a NUCLEO-WBA52CG boar after running the GPIO_IOToggle_TrustZone Example an both LEDs working as expected i encountered the error Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
after switching from RP Level 1 to RP Level 0 and deactivating the TZEN Option bit
2024-03-12 02:12 AM
2024-03-12 02:12 AM
2024-03-12 02:34 AM
Hello @STTwo-32
can you explain to me how the process works and what exactly i nee to do
regards
Isko
2024-03-12 03:04 AM
