Error in initializing ST-LINK device. Reason: (18) Could not verify ST device! Abort connection.
‎2019-10-18 3:38 PM
I'm having an issue using STM32CubeIDE to program my blue pill boards. I get the below error each time.
Error in final launch sequence:
The strange thing is I have no issue programming my boards using ST-Link Utility. I thought that maybe the chips on my boards were counterfeit but I've tried boards from multiple venders now.
I've looked around online and while I found some people getting the "Error in initializing ST-LINK device." message I haven't seen anyone getting "Reason: (18)".
Any help would be appreciated.
ST-Link
STM32CubeIDE
STM32F1 Series
‎2019-10-22 3:10 PM
Ok, I solved it so I figured I'd update in case anyone comes across this thread in the future. It was 100% due to there being a counterfeit chip on my blue pill board. I bought some chips from DigiKey and used a hot air rework station to swap them out. I no longer get the error message I was seeing.
Beware of venders with counterfeit chips!
‎2019-10-22 5:27 PM
I have this exact problem, though when using CubeProgrammer, it does upload to the Blue pill. However using the CubeIDE, I get this error message trying to flash it. Are you sure the actual chip was the problem?
‎2019-10-22 7:57 PM
I'm pretty sure, man. Error 18 has to due with not being able to verify the MCU. Then once I put a new, known good, MCU on the board everything programmed as expected. Lots of blue pills has counterfeit MCUs on them. That's why they are so cheap.
‎2019-10-22 8:02 PM
Do you think that the problem is only with the CubeIDE not being able to detect none-originial MCUs/linkers but that it works with others? Do you also use the mini st-link v2 USB?
‎2019-10-23 6:07 AM
I could always program using St-Link Utility. I've read that the St-Link Utility doesn't check for valid MCUs before programming but that STM32CubeIDE does check. I wanted it to work with the IDE so I could use debugging.
I do use the Mini ST-Link V2 USB programmer.
‎2019-10-23 6:51 AM
The ST-Link utility is, AFAIK, not longer maintained or updated, while the CubeProgrammer is pushed as it's replacement.
Counterfeits might have been less of a problem during the lifetime of the ST-Link Utility, explaining the absence respective checks.
‎2020-05-15 6:16 PM
Yes, hate the blue pill with clone MCU on it. In my case I have a CKS32F103… instead of STM32F103…
However, if you do end up with one, there is a way to get it working with OpenOCD. >>
1. Use OpenOCD as your debugger (GDB will not work)
2. Find the config file : stm32f1x.cfg
Location is similar to this : >>
C:\ST\STM32CubeIDE_1.3.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.debug.openocd_1.3.0.202002181050\resources\openocd\st_scripts\target
3. Add the following near the top of stm32f1x.cfg (before the first If – statement):
set CPUTAPID 0
The zero tells OpenOCD to ignore id numbers, which means all clones or genuine MCUs will work.
4. Save the changes. Now your flash and debug should work.
Note: If you change to OpenOCD without changing “stm32f1x.cfg�?, you will get the following Error: “UNEXPECTED idcode: 0x2ba01477…. Expected: 0x1ba01477�?, and you will again be stuck.
Information Source: http://openocd.org/doc/html/TAP-Declaration.html#TAP-Declaration-Commands
‎2020-06-06 7:36 AM
I have done as you mentioned above. After that I am getting another type of error -->
Failed to execute MI command:
load C:\\Users\\Acer\\Downloads\\Embedde-C\\My_workspace\\Target\\LED_Blink\\Debug\\LED_Blink.elf
Error message from debugger back end:
Error erasing flash with vFlashErase packet
Please let me know if you have any idea regarding this problem.
‎2020-06-06 5:33 PM
Yes, I can help you with that. The reset is not working. Try this>>
On the “Debug Configurations�? – page (where you changed “Debug probe�? from …GDB to …OpenOCD), there is one more thing to do >>
- Click: “Show generator options…�?
- Change: “Reset Mode�? to “Software system reset�?
- “Apply�? that, and try again
