Correction Request: non-existent part number recommended in eval board manual UM1974
BarryWhit
Senior III
Dear ST,
In UM1974 rev 10, section 6.8.1, page 25/84 a recommendation is given for the use of a particular crystal part number:
This part number does not exist.
I've searched on both Digikey and LCSC and in both there is only the part number
NX3225GD-8MHZ-EXS00A-CG04874
Please correct the document.
- If someone's post helped resolve your issue, please thank them by clicking "Accept as Solution".
- Please post an update with details once you've solved your issue. Your experience may help others.
2 REPLIES 2
FBL
Hi @BarryWhit
Thank you. Good catch
An internal ticket 185310 has been reported to update the UM1974. It could be any crystal that is inline with AN2867.
BarryWhit
Senior III
Thank you for the quick response.
