2024-07-03 12:07 AM - last edited on 2024-07-03 05:06 AM by Andrew Neil
Hiii everyone!!!! i want to use ADXL345 as accelerometer by using spi communicatiton and debug and display the value of respective axis in any serial monitor. Please give me the respective code for my guidiance.
2024-07-03 05:04 AM
@Shaku wrote:Please give me the respective code for my guidiance.
You need to write your own code - this is not a free code-writing service!
If you want someone to do your project for you, try somewhere like:
@Shaku wrote:i want to use ADXL345 as accelerometer by using spi communicatiton and debug and display the value of respective axis in any serial monitor.
So you have two things to do there:
I would suggest that you start with using the UART to send stuff to a terminal - as that will also be useful for debugging.
You can find plenty of examples of using both UART and SPI on STM32 from ST and 3rd parties.
For specific details of how to communicate with the ADXL345, go to its manufacturer:
https://www.analog.com/en/products/adxl345.html
2024-07-03 05:49 AM
I'd worry about my job if ChatGPT can do it better than I can...
