2023-11-03 6:51 AM
My application used ST25R3916B for transmit power for the card only.
1. Is it possible to leave the EXT_LM pin unused or exclude external load modulation from my application?
2. Can I use the testing point only on the pin EXT_LM pin?
Best,
Dalik LIM
2023-11-06 1:23 AM
Hi Dalik,
not sure I completely understand: Using EXT_LM is a possibility in the chip. Technically it can work without. Foreseeing a testpoint is always a good idea.
Regards, Ulysses
2023-11-06 1:23 AM
Hi Dalik,
Regards, Ulysses
