2020-05-03 10:47 PM
I bought ST25RU3993-EVAL board.I want to reading tag's id. Can I make serial communication? I write console "minicom" .Then i set baudrate=3000000 and 8N1 and no flow control. But there is no text in terminal. How to make serial communication?
2020-05-21 01:03 AM
I would like to summarize our project and situation to you in order to be on the same page :
We bought an A0025 antenna . And we want to get the item count in the fridge . We are working on Raspberry Pi 4 . We use usb3.0 port of RPI4 in order to give power to the ST25RU3993 Eval Board .
When we use your Windows GUI we can get item count correctly . But, once we use the RPI4 , we can not read the tag count correctly . Also we can not read the tags from long distance(30cm+) .
What functions should we use to set the correct values in main.c ? Or should we change another .c file ?
Since the project is so important to us , we would like to solve the problems . We are working on this project for a really big company . So if can achive the demonstration they will order huge amont . It is really a big project.
Thanks for your support ,
Regards ,
Ulas
2020-05-21 07:40 AM
Hello Uyalc,
The fact you are able to use windows GUI is really good, indeed what I can suggest for you to get the best appropriate parameters to be used in your Linux application is:
The functions you have to address for your configuration update are mainly the ones in setupGen2Config() (file STUHFL_DemoEvalAPI.c) + the tuning ones ;)
best regards,
Cedric.
