2022-08-18 07:12 PM
Dear Sir,
In order to check the RFAL functions with sample project in ST25NFC_Embedded_Lib_ST25R3916_1.4.0\Projects\STM32L476RG-Nucleo\Applications,
I bought a X-NUCLEO-NFC06A1. I have a STM32F401RE nucleo board already, I wonder
if the two board can be used for checking function without any modification of the sample code.
If any modification is necessary, would you like to inform me the related information.
best regards
Dai Sai
2022-08-22 01:44 AM
projects in ST25NFC_Embedded_Lib_ST25R3916_1.4.0 can be directly used on NUCLEO-L476RG.
For other Nucleo boards, a porting is needed (see tutorial in https://community.st.com/s/question/0D53W00001Px5sKSAR/how-to-create-a-project-with-x-cube-nfc06).
Rgds
BT
2022-08-18 07:36 PM
I plan to use STM32CubeIDE for checking. I installed the STM32CubeIDE for window,
but can not find any project file with "Import Project" selection.
any help for me?
best regards
Dai Sai
2022-08-22 01:44 AM
Rgds
BT
2022-08-22 06:37 PM
Dear Brain,
thank you for your reply. It seems my environment is good for checking function now.
If necessary, I will try to use STM32CubeIDE.
best regards
Dai Sai
