Wireless power transfer to rotating collector
HPCCSystem
(Split from: https://community.st.com/t5/power-management/induction-cooktop/m-p/731743)
Hi everyone,
I am wondering if anybody can help on an improper use of the induction cooktop .
I've received an ST email featuring the STEVAL-KITXCB and it is very interesting for an unrelated application not involving appliance. Basically I need to transfer a lot of power to some electronics which is mounted on a rotating cylinder. At moment I am using a rotating collector, but it has a short life and is very expensive. I watch the video on the page promoting the kit and I saw the water boiler getting power from the stove top while it was moved around the surface and lifted. I downloaded the DB5153, which it shows in detail the kit, but I can find any information on how to build the receiving part. Basically, in your expert opinion, can I created a rotating receiver for transfering power to my electronics? The power requirement it's pretty much what's the kit is proposing. I visited the Wireless Power Consortium which it's developing the standard but I could not found any information. Maybe I just misunderstood what the kit is working. Eventually I can explain in more details my application.
Thanks for any advice I can get.
Carlo
4 REPLIES 4
As noted in the other thread, for details of the kit you probably need to contact ST direct, or your local FAE/Distributor.
 https://ols.st.com/s/
https://www.st.com/content/st_com/en/contact-us.html
Thanks Andrew,
I did contact ST direct , but they said my enquiry was beyond the scope of the application. In their answer they noted that my request needs an in-depth analysis and for that reason they suggest to look in  https://www.st.com/content/st_com/en/partner/partner-program.html#1 or in this community.
I search in the various section of the link but I could not find any ST partner involve in this technology so I took a shot in the community.
Carlo
willzhou
Hi
let me contract internal to find related doc.
Thanks Willzhou,
any information it's greatly appreciated. Mainly to find out if my idea is far fetched or maybe there is a possibility.
Carlo
