Which parts are pin compatible replacements for the VN7140AJTR?
‎2017-10-16 12:17 PM
I need to find suitable alternatives to the VN7140AJTR that can swapped in with zero board changes.
Is there a complete list of replacement parts available?
It looks like the VN7040AJTR is a pin compatible replacement. Can I use the VN7140AJTR and VN7040AJTR interchangeably?
Thanks,
Brian
#vn7140ajtr #vn7040ajtrSolved! Go to Solution.
Motor Control Hardware
‎2017-10-19 6:08 AM
Hello Brian,
you can replace the
VN7140AJTR with
VN7040AJTR, VN7050AJTR, VN7020AJTR.
They are fully pin to pin compatible, please have a look to the following page:
Best regards
‎2017-10-19 6:08 AM
Hello Brian,
you can replace the
VN7140AJTR with
Best regards
‎2017-10-19 11:15 AM
Thank you for your response!
I appreciate the help.
