What is IC smd 14 pin marking code UAPS?
‎2024-10-10 10:11 PM
I try to search ST products datasheet for ic smd package 14 pin marking code UAPS and EZM7117.
What is IC and datasheet?
Thank You.
Battery Management
‎2024-10-11 12:36 AM
Welcome @Srip, to the community!
It is an obsolete device where no information or data sheet is available anymore.
I'm sorry I can't give you a more positive answer.
/Peter
/Peter
‎2024-10-11 12:49 AM
Yes this ic part from Braun old electric shaver.
Thank you for your reply.
