Identify this Unknown component?
  • December 11, 2024
  • 5 replies
  • 1619 views
Hi, I'm having trouble identifiying an ST part from marking code.
Component is a 8 pin IC.
Code is as below:
First line: 3s128wt
First line: k952k
Thank you !
Best regards, M
Andrew Neil
You've posted in 'Interface and connectivity ICs' - does that mean you have reason to believe that it is an 'Interface' or 'connectivity' IC?
Similarly with the IO-Link tag?
MatjaAuthor
Hi, I accidentally done that, I wanted to post in Others: hardware and software, since I believe is EEPROM device.
will try to re-post it in that discussion and delete this one.
I apologize..
I've moved it for you.
Peter BENSCH
@Matja Please upload a legible photo of your device.
/Peter
Tesla DeLorean
Tesla DeLoreanBest answer
Guru
December 11, 2024
MatjaAuthor
You are correct, i didn”t saw that as a 5, thank you very much for your help ad solving my issue !
I was hoping to find the part number in order to buy it from Farnell/Mouser, but I see this is a custom part…
Wish you a good day !
