2016-03-30 1:29 AM
We need to settle a difference of opinion interpreting the data sheet for the VND5T050AK-E, dual channel high-side driver IC.
We agree that when you provide a normal load, the CSn output acts as a current source whose current is a rough fraction of the actual output current on channel n.
When you overload the output however, the channel switches into fault mode and the CSn output does something else.
Does anybody know for sure? Is it somewhere in the data sheet and I just can't find it?
Thanks.
#high-side-driver-overcurrent #support2016-03-30 3:39 AM
Correction: Change that second assertion to:
statement 5 trumps statement 4.
2016-09-14 5:45 AM
I originally posted this question 6 months ago and it remains unanswered. In fact,
so far the only person to follow up was when I corrected a typo in my original post.Now I am looking at the big board for ''Motor Driver ICs and Boards'' and estimate
that 80% of the posts have 0 follow-up, which begs the question:''Does anyone from ST ever look at these requests for support?''
(If you're not there, please don't answer.)
