Power management
Discuss power management solutions. Ask questions and find answers on voltage configurations, short circuit protection, and programming.
Information and waveform plots missing for L9758 datasheet
Hi,Can we have some more data for L9758? Datasheet provides very less information. Typical application schematic (external components values/part numbers)Typical performance characteristicsStart-up, efficiency, shutdown, load and line transients wave...
FCuti by Associate
  • 646 Views
  • 0 replies
Information and waveforms plot missing in L9945 Datasheet
Hi,Can we have some more data for L9945? Datasheet provides very less information. Some timing waveforms for all 8 channels(or may be only one channel, which can be replicated for the other 7 channels). Functional block diagramTypical application sch...
FCuti by Associate
  • 680 Views
  • 0 replies
Chip markings on the STSPIN32F0A
I recently purchased these from element14: https://in.element14.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&langId=91&urlRequestType=Base&partNumber=2797963&storeId=10186.The ones I got show this as the chip marking: https://i.imgur....
Resistor guidelines for LDL212 adjustable
Have specified LDL212 adjustable regulator in new device. Very limited information in the datasheet for selecting the R1 and R2 values. Assistance appreciated. Target VOUT is 3.6VThanks in advance
DFloh.17 by Associate
  • 845 Views
  • 0 replies
Currently I am using "STEVAL-SPIN3202" with "STSW-SPIN3202" to drive a 12V/30W, 16-pole BLDC motor by sensorless control.
However, when I pressed the button USER1 on "STEVAL-SPIN3202", the rotor spun for couple turns and then stalled. I did it several times, but got the same results. I have checked p.50 of UM2310, but haven't got the motor running. What are possibilitoe...
MChen.19 by Associate
  • 558 Views
  • 0 replies
How long will STTH810D diode last at Tj = 126degC?
We are using the STTH810D in our new 60W offline  Flyback LED driver. It is dissipating 4W. We measured its metal tab as operating at 115degC. Therefore its junction is operating at 126degC.This product is supposed to operate for 8 hours per night , ...
amass.9 by Associate II
  • 658 Views
  • 0 replies
