2024-02-09 03:23 AM
Please advise where I can find the device marking for TS4061AILT-1.225. I was expecting to find it in the datasheet but it doesn't appear to be in there. Maybe a more general question would be how does ST disseminate such information if not in the datasheet?
2024-02-09 10:36 AM
Welcome @Ted_Murphy, to the community!
The marking information can be found in the data sheet for some components (mostly discrete components such as Schottky, etc.), but is otherwise non-public information. However, we are happy to provide this information here. In your case of the TS4061AILT-1.225, the marking is 62A, but can also be found on the label on the packaging bag.
Hope that helps?
/Peter
2024-02-09 10:36 AM
Hope that helps?
/Peter
