2021-10-08 7:47 AM
In p. 28 of Datasheet - STPMIC1 - Highly integrated power management IC for micro processor units, 4.2.1, it says:
3. Manually by setting VOUT[4:0] field of Table 38. BUCKx_MAIN_CR or Table 43. BUCKx_ALT_CR registers. Refer to Table 9. LDO output voltage settings.
Does it mean the BUCK regs will determine the LDOs' VOUT?????
Thanks.
2021-10-19 12:46 AM
Thank you very much for reporting this typo.
The line:
should be read as:
It will be corrected in one of the next updates of the datasheet.
/Peter
