POWERSTEP01, When in external step mode, how does KVAL get calculated for VOLTAGE MODE?
CBeif.1
I know that Vout = Vs * Kval
I know that
Kval = [(Kval_x * BEMF_COMP) * VSCOMP * K_THERM]*microstep
In the datasheet KVal_x is either KVAL_ACC, KVAL_DEC, KVAL_RUN, or KVAL_HOLD
depending on the state of the motion planner.
But, I am not using the internal motion planner, I am providing an external
step pin. So how do I control the Kval in this situation?
3 REPLIES 3
Cristiana SCARAMEL
In Step-clock mode the SPEED register is set to zero and motor status is considered stopped regardless of the STCK signal frequency.
So you need to consider the KVAL_HOLD.
If you feel a post has answered your question, please click "Accept as Solution"
Thanks, Does that also mean BEMF compensation does not work in external STEP MODE?
Acceleration compensation curve is applied when the motor runs.
No BEMF compensation is applied when the motor is stopped as is in fact considered the motor in step-clock mode.
