2024-06-11 03:25 AM
Hi, i'm trying to power an usb-c device that needs 5v 2A, with a power supply (5v 8A) that doesn't support power delivery. For doing that i tried to use the evaluation board EVAL-SCS002V1 connecting the power supply wires (+ and -) to the green connector and the usb-c one to the device to power on. The result is that only the board blu led is turning on that means "default USB current".
How can i negotiate for more current? What am i doing wrong?
Please help me 🙏.
Giacomo
2024-06-12 07:36 AM - last edited on 2024-06-12 07:47 AM by Peter BENSCH
Hi
Please check this doc, it need to modify some register.
pm0265-managing-usbc-port-status-with-the-stusb4500l--stmicroelectronics.pdf
Hi
