2023-06-23 01:53 AM
The register map of L9961 BMS IC is missing from the datasheet, where can i find it?
2023-06-26 11:01 PM
It is in the latest datasheet dated 18th Jan 2023 -
https://www.st.com/en/power-management/l9961.html#documentation
2023-06-26 11:01 PM
2023-11-09 06:43 AM
I tried the solution but cannot find the attachment in the pdf.
Is there maybe a place where I can download the register map.
2023-11-13 06:04 PM
The register map was missing from the latest V4.0 datasheet previously. It has been re-attached in the website now. Please download and try again.
2023-11-14 04:47 AM
Thanks 👍.
