2024-01-30 08:17 AM - last edited on 2024-02-01 01:30 AM by Peter BENSCH
Hi frds,
I've choose blue color led, that led works mention voltage & current, but my doubts is i choosed driver led driver for each LED, Which one is best ?, pls suggest anyone....
This part no's
LED2001PH
LED2000DR
ST1CC40DR
2024-02-01 01:49 AM
To be able to recommend a suitable LED Driver, we need to know a few basic parameters:
You can also use the eDesignSuite for simulation and design, which can suggest the right devices for you if you select LED Lighting Design Tool, choose the type of the supply (DC/DC or AC/DC) and start the design.
/Peter
