I am using STPM34 for measuring RMS voltages. When I measure grid voltages it's fine. But I read the inverter output voltage, the value is oscillating from 0 to 500v. Please help me to resolve this.
THANGAMUTHU
6 REPLIES 6
Peter BENSCH
What is the inverter output voltage: AC or DC?
When AC: what frequency?
How did you connect the STPM34 to this voltage?
/Peter
THANGAMUTHU
Inverter Output voltage : 200 - 270V AC
Frequency : 50Hz
Javier1
Principal
we need to see te code aswell, did you probed the inverter output with an oscilloscope?
Maybe is much much noisier and spikey than you expect. (specially with no load attached)
we dont need to firmware by ourselves, lets talk
THANGAMUTHU
V factor = VREF * (1 + (R1 / R2)) / (AU * CALIB_V * DPOW)
        = (1.18 * (1+ (810000/470))) / ( 2 * 0,875) = 116274,11
I factor = VREF / (AI * CALIB_I * DPOW * KSI * KINT )
        = 1.18 / (2 * 0,875 * 0,00260 * 1) = 25934,06
By using the above formula we calculated Voltage and Current. For Grid Voltage STPM34 is reading Correctly, we are facing the issue when reading inverter output AC voltage. I have attached waveforms across the VIP1 pin. I have changed the Capacitor across VIP1 pin 10nF to 100nF but also facing the issue same.0693W000008xtAVQAY.jpg0693W000008xtABQAY.jpg0693W000008xtA6QAI.jpg
that looks like a very noisy signal.....
What about triggering the ADC reading only when the pwm event?
THANGAMUTHU
Kindly Suggest proceeding further?
  1. Grid Input
  2. Inverter Input
