2024-09-12 10:55 PM - edited 2024-09-18 5:37 PM
I use the STWLC38 for wireless charging.
Just set the BPP VOUT to 9V, and other REG is in default value.
In test , the output current around 0.6A . (The chip emits a squealing sound)
If I want to set the Rx to 15W, which REG I need to set.
And I have a question about the RX LDO configuration in datasheet。 There is no detailed explanation regarding the threshold. How should these registers be configured?
Thank you!
2024-11-16 7:34 PM
Hi
please enable RX NEG for EPP mode use GUI, or you can use this link epp file.
https://github.com/STwirelesscharger/STSW-WPSTUDIO/blob/main/a12_wlc38_downfw_epp.bat
2024-11-16 7:34 PM
Hi
