High side configuration for TD350E
2023-01-16 7:09 AM
I'm trying to develop a 400V 3 phase inverter for a motor controller. I was looking at TD350E to drive the IGBTs. Can this be used on the high side or in a half bridge configuration?
Motor Control Hardware
2023-01-17 1:04 AM
Hello @jnelectric1 and welcome to the ST Community.
The TD350 is a single gate driver and can be used for high side driving and / or half bridge configuration.
You can find more detail in the Application Note AN1944
Let me know if this info is useful to you, if yes please "Select as Best" label.
2023-01-17 1:04 AM
