2020-10-11 10:56 PM
2020-11-21 11:18 AM
Look at the International Rectifer(Infıneon) Ballast Designer Program, which is highly recommended to use for ballast circuits in great case for long time use and use mainly IR2520D and L6561/L6562D Ic Models.
By the way, for Ballast design over 40W, you should deal with PFC IC/Circuits for more realible and stable in each Grid Voltage Levels.
