Configure hall sensor on STM32_ini.c from Keil
‎2011-09-06 12:29 PM
Hi guys,
I need some help to configure TIM4 for hall sensor. the STM32_ini.c is attach.- Labels:
Motor Control Hardware
‎2011-09-07 04:44 PM
Any help?
so, my motor speed is 5000rpm what is the best config of PSC for timer not overflow?// define timer clock
// between two changes on the hall sensor lines on the lowest rotation
// speed (eg. 1/100 from max. speed) the timer must not overflow
// define timer counter clock appropriate
// timer base configuration// 126 => 3,5s till overflow ; 285,714kHz TimerClock [36MHz/Prescaler]
TIM_TimeBaseStructure.TIM_Prescaler
=126
; TIM_TimeBaseStructure.TIM_CounterMode
= TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_Period
=65535
; TIM_TimeBaseStructure.TIM_ClockDivision
=0
; TIM_TimeBaseStructure.TIM_RepetitionCounter
=0
; TIM_TimeBaseInit(
TIM4, &TIM_TimeBaseStructure)
; i not understand why 126- Mark as New
‎2011-09-08 09:12 AM
sorry, I do not know how it's configured in the Keil source example. Anyhow, there's a similar module in the STM32 PMSM FOC SDK v3.0 to handle Hall sensor signals, here below an excerpt of the timer peripheral configuration:
... /* Set full 16-bit working range */ TIM_HALLTimeBaseInitStructure.TIM_Period = U16_MAX; TIM_HALLTimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseInit(TIMx,&TIM_HALLTimeBaseInitStructure); TIM_ICStructInit(&TIM_HALLICInitStructure); TIM_HALLICInitStructure.TIM_Channel = TIM_Channel_1; TIM_HALLICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling; TIM_HALLICInitStructure.TIM_ICFilter = pDParams_str->hInpCaptFilter; TIM_ICInit(TIMx,&TIM_HALLICInitStructure); /* Force input capture from TRC */ /* Disable the Channel 1: Reset the CC1E Bit */ TIMx->CCER &= CCER_CC1E_Reset; TIMx->CCMR1 |= 0x03u; /* CCS1 = 0b11; */ TIMx->CCER |= CCER_CC1E_Set; /* Force the TIMx prescaler with immediate access (no need of an update event) */ TIM_PrescalerConfig(TIMx, (u16) pDVars_str->hHALLMaxRatio, TIM_PSCReloadMode_Immediate); TIM_InternalClockConfig(TIMx); /* Enables the XOR of channel 1, channel2 and channel3 */ TIM_SelectHallSensor(TIMx, ENABLE); TIM_SelectInputTrigger(TIMx, TIM_TS_TI1F_ED); TIM_SelectSlaveMode(TIMx,TIM_SlaveMode_Reset); /* Source of Update event is only counter overflow/underflow */ TIM_UpdateRequestConfig(TIMx, TIM_UpdateSource_Regular); ...With this setup, the counter is reset every time there's a rising or falling edge on each of the internally XORed H1,H2,H3 (TI1F_ED, which is the OR of TI1F_Rising and TI1F_Falling, is used as trigger input by the slave mode controller) and its last value is stored in the CCR1 (TRC is used to force a capture). Figure 77 - in the STM32 reference Manual (RM0008) - is explanatory.
About the prescaler, in the SDK's Hall sensor module, it's constantly adjusted in order to always have the best resolution. I invite you to have a look at the User Manual UM1052, figures 44, 45 and 46.
Best regards,
DinoAny help?
=126
=65535
=0
=0
; TIM_TimeBaseInit(
‎2011-09-08 04:24 PM
I download the FOC lib and install but not found the file with that code.
I appreciate
dino
King Regards Vitor Soares- Mark as New
‎2011-09-12 12:26 AM
the source name is ''HALL_SpeednPosFdbkClass.c'' and it belongs to the MC library, a compiled layer in the SDK web distribution you have downloaded. Source code of this layer - with the exception of specific algorithms such as the sensorless state observer - is included in the SDK confidential distribution, free of charge and on demand by contacting your nearest ST sales office or support team. Best regards, Dino
