2020-09-14 09:29 PM
2020-09-15 08:53 PM
This info is already available in the datasheet. It has the max frequency limit in the table. There are timing diagrams related to interlocking for the PWM inputs and also for the SmartShutdown function including application information. Do you have any specific query?
2020-09-15 08:53 PM
2020-09-24 01:30 AM
Hi @CVT.1,
the @uomo motore's answer solved your doubts?
If yes please "Select as Best", otherwise as abovementioned do you have any specific query?
