IAR - Redirect printf to UART and fprintf to SD card FAT File system
2022-09-07 8:36 AM
I am using IAR EWARM 9.10.2 and would like to redirect printf to UART and fopen/fclose/fprintf to SD card hosting FAT File System(R0.12c (March 04, 2017)). Any guide on how to do redirect io streams on IAR would be helpful.
Thanks in advance.
FatFS
IAR
SDIO-SDMMC
STM32H7 Series
UART-USART
2022-09-07 8:55 AM
https://wwwfiles.iar.com/arm/webic/doc/ewarm_developmentguide.enu.pdf
Is suspect you need to replace __write function with your own, or redirect the linker to use yours rather than it's own.
--redirect __write=__write_kgane
2022-09-07 10:17 AM
@Community member Thank you!.
I tried redirecting fpintf to SD card. I found templates for file operation in \IAR Systems\Embedded Workbench 9.0\arm\src\lib\file.
Implemented __open/__close/__write/__read/__/lseek. When running code in IAR debug mode, the execution trapped using BKPT instruction. Seems the IDE is semi-hosting.
2022-09-07 10:26 AM
Perhaps a check-box item in the project/build metadata, or can be changed via a #pragma
Sorry, team Keil here, but I'd expect IAR would facilitate relatively easily
https://stackoverflow.com/questions/10503680/use-of-arm-semihosting
Some of the redirect examples talk of the buffered write, where you provide that functionality.
--redirect __write=__write_bufferred
2022-09-08 1:10 PM
Just select a non-minimal variant of the IAR runtime library, that uses file handles (or descriptors).
Do not select semihosting, of course.
Then your _write replacement will receive the file handle/descriptor number.
Send the data for different descriptors to different destinations, as you like. Values 1 and 2 are stdout and stderr.
2022-09-09 2:48 PM
@Community member , @Pavel A. Thank You.
I can redirect to both UART and SD Card using "Full" Library Configuration. I had to disable "Buffered terminal output" in IAR. In addition to own implementation of __open/__close/__write/__read/__/lseek, putchar and getchar needs modification to call to UART TX & RX functions.
The following TN is useful.
