2007-03-14 9:43 AM
2007-03-13 10:32 PM
I have spent way too much time trying to figure this out...
When I am running IdeaST7 and I go to Build -> Setup Tools -> Debugger -> Application, exactly *what* is the name of the .exe I should find to be able to run the Zap debugger? Thanks! -David2007-03-14 3:04 AM
Unless you have a reason for using zap i would really recommend you use ST Visual Develop, available on this website.
Regards sjo2007-03-14 9:43 AM
