2024-12-11 05:08 AM - last edited on 2024-12-11 08:13 AM by Andrew Neil
Hi
could you advise what the part marking is for below, please?
Kind regards
Mayura
2024-12-12 04:43 AM - edited 2024-12-13 04:18 AM
Look at the last pages of the datasheets.
Example for M24C64-DFMC6TG / Ordering information. The marking is detailed here:
If that does not answer your question please open an OLS ticket over this link: https://ols.st.com/or contact your local sales.
2024-12-11 07:38 AM - edited 2024-12-11 07:45 AM
1- M24C64-DFMC6TG: 64-Kbit Serial I2C bus EEPROM: https://www.st.com/en/memories/m24c64-df.html
2- ASM330LHHXTR: High-accuracy 6-axis automotive inertial sensor: https://www.st.com/en/mems-and-sensors/asm330lhhx.html
3- STTS22HTR: Ultralow-power temperature sensor: https://www.st.com/en/mems-and-sensors/stts22h.html
4- LIS2MDLTR: Ultralow-power magnetic sensor: https://www.st.com/en/mems-and-sensors/lis2mdl.html
Go to Documentation tab for the related datasheets:
Hope it helps.
2024-12-12 04:11 AM
Hi SofLit,
There is nowhere in the datasheet to mention top marking, could you please advise what the marking is?
Mayura
