Teseo-LIV3FL Low Power Mode Not Working
2023-02-08 11:25 PM
I'm using a Teseo-LIV3FL GNSS module for my project and trying to set the low power mode settings using Teseo-Suite software. Tried using the Low Power settings from the wizard but after get the fix it still draws around 50mA of current.
Expected behavior: After getting a fix it'll go to sleep for certain period of time (around 60s and only draws small amount of current) before logging the data again (periodic low power mode I guess (?))
What is the correct way to achieve the expected behavior?
2023-02-09 12:25 AM
Hello @AFidi.1
Have you checked the software user manual ?
2023-02-09 8:17 AM
Yes I've checked the manual. I also tried sent the command manually but still no luck.
$PSTMSETPAR,1200,E70000,2
$PSTMSETPAR,1200,E70000,1
$PSTMSETPAR,1227,3C0,2
$PSTMSETPAR,1227,C0,1
$PSTMSAVEPAR
$PSTMSRR
Rebooted di GNSS firmware and still no luck.
2023-02-11 9:25 PM
Hello, @AFidi.1
In case if you use an external antenna, Teseo doesn't turns off antenna's power line (X-Nucleo GNSS board with Teseo-liv3f), as I understand. May be it will be usefull to check power consumption without any antenna.
2023-02-11 9:35 PM
Also, to turn ON the Low power algorithm you need to set-up the 31 bit of CDB-ID 200:
$PSTMSETPAR,1200,80E70000,2
2023-02-12 3:02 AM
Thank you for your response. Anyway, I've tried using $PSTMLOWPOWERONOFF and now its working as expected.
However, now I got another issue. I'm trying to set geofence using $PSTMGEOFENCECFG and it says $PSTMGEOFENCECFGERROR*06 and here's the command that I sent to my Teseo.
Do you know where did I go wrong? I'm kinda lost since it only says error without any details.
2023-02-12 8:06 PM
May be, ID should start from 1?
2023-02-12 8:08 PM
And radius value format as double: 1200.0?
