Teseo-LIV3F : NMEA messages
KSamn.1
I am facing problem Teseo-LIV3F is not sending out any NMEA messages and also not accept any commands. Anyone know Why? and How to set back to "Factory Setting" ?
3 REPLIES 3
Javier1
Principal
what if the Teseo is working but your uart config is wrong?
If i were you i would stick an oscillocope/logic analizer on those RX/TX traces
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
I sticked an oscillocope/logic on Pin2(UART_TX) but I could not see any signal coming out.
Before I sent command to change uart baurate to 38400 i received NMEA messages from Pin2.
Do you have any idea what happpened with uart config?
The command I send to change baurate is: PSTMCFGPORT,0,0,1,38400
https://www.st.com/resource/en/user_manual/um2229-teseoliv3-gnss-module--software-manual-stmicroelectronics.pdf
What if you try to do a FW update or recovery?
