STR912FA (IAR Eval board) - Help on Startup files
Options
‎2008-07-08 11:25 AM
Posted on July 08, 2008 at 20:25
Labels:
Legacy Products
Options
‎2011-05-17 12:54 AM
Posted on May 17, 2011 at 09:54
I am using STR912FAW44x6 eval board from IAR. The LED blinky program (RAM version)from ST library works fine. I am trying to download and run the program (ROM version) from flash. I am using the ST startup files (91x_init.s and Vectors.s) from ST Micro STR91xFA Rev 2.0 Firmware Library (RVDMK). The program control doesnt switch to /reach Main. Advice on start up sequence, vectors, sample code etc. Rgds, Rushoth.Options
I'm using GreenHills MULTI V5.0.3(C compiler).
Rgds Rushoth
