2008-06-23 06:02 AM
2011-05-17 12:53 AM
hello,
we are using SPI port as a master connected to onother MCU should we use pull up resistors in between because the signal could be visualized in oscilloscop without connection once we connect SPI master to slave the signal disapears Thanks in advance
