2005-05-25 09:05 PM
2005-05-24 01:44 AM
What is the MPAR register used for if DAC=1, DTE=0, PCN=0 ? i.e.
Motor controller in direct access mode, only PWM U signal connected to channel manager, dead time generator disabled ! I just want to control a brushed DC motor (only one direction includind brake) with outputs MC00 (Low side) and MC01 (Highside for braking)2005-05-25 09:05 PM
Your posted your question in the ST6 forum, you should have done it either in the ST7 or motor control one.
Post it again if you want someone to answer.
