2006-02-16 12:08 AM
2006-02-09 05:10 AM
I am porting a design to the new ST7FLIT19B device.
I have noticed that the simulator supports this device, but it does not work as expeceted. No registers show up in the peripheral window and the plotter does not work. The peripheral window windows says - no port defined. If i change back to a ST7FLITE19 then all is ok. Any ideas ? Regards sjo2006-02-16 12:08 AM
You are totally right, there is some misfunctionning with the Lite19b simulator.
We are working to fix them in the next release. Best regards Laurent
