2006-02-16 12:02 AM
2006-02-13 1:38 AM
Hello.
I am using st7MC with HDFlash therefore micro needs 12V on Vpp. I do many write cycles to flash my code, and after every write cycle micro waits for next part of data for some time. The question is : do i need to switch 12V off after every write cycle while micro is waiting and again switch 12V on exactly before writing? Or it is enough to switch 12V on before first writing cycle and switch off after last one? Tnx in advance.2006-02-16 12:01 AM
hello Luter,
You are right you can let the VPP on between two programmings. Best regards Laurent2006-02-16 12:02 AM
hello Luter,
