Regarding Serial communication between STM32 Nucleo F401RE and Labview
‎2025-01-13 9:15 PM
Dear ST community,
I want to send some data (like an integer or a decimal number) from Labview to the STM32 Nucleo F401RE board for motor speed controlling application.
I have tried using NI DAQ (using digital output pins) and NI VISA. i am finding it difficult to get the output.
what are the steps to be taken ?
Regards,
Shruthi
- Labels:
STM32CubeIDE
‎2025-01-14 12:50 AM - edited ‎2025-01-14 12:53 AM
@Shruthi1 wrote:I have tried using NI DAQ (using digital output pins) and NI VISA. i am finding it difficult to get the output.
That's a question about NI DAQ and/or NI VISA - neither of which has anything to do with ST or the STM32.
You need to go to NI for help with their tools:
https://www.ni.com/en/support.html
@Shruthi1 wrote:I want to send some data (like an integer or a decimal number) from Labview to the STM32 Nucleo F401RE board Shruthi
As far as the STM32 is concerned, that's purely about receiving serial data - the NI stuff is irrelevant.
The STM32 neither knows nor cares what generates the data - all it sees is bytes arriving at the UART's RX pin.
You can test your STM32's UART reception just using a simple serial terminal:
https://wiki.st.com/stm32mcu/wiki/Getting_started_with_UART
