Program ST10R167
fabien2
Posted on May 30, 2007 at 07:38
Program ST10R167
3 REPLIES 3
fabien2
Posted on May 29, 2007 at 12:27
I'm new and I have a question of beginner.
So I have a ST10R167 and I wish to program it. If I have understood, this ic have an internal rom and I have already an ic programmed.
Can I recover his program to send it in another empty ic ?
If yes, which software could I use to ?
Can I use the software st10flasher 2.4 ?
Can I use a converter base DIL48/PQFP144 to program it (because I have
a device programmer DIL48)?
Is it possible that I cannot read the program (program locked in reading) ?
In fact, I just want to copy/stick the program.
Thank you for your answer.
fabien2
Posted on May 30, 2007 at 05:29
Hello Neila,
Thanks for your quick answer but I don't understand !
Here it is the block diagram, and you can see just like me an internal rom
takes part in the functional mode of the ST10R167-Q3.
ST10R167 > R for ROM
ST10F... > F for FLASH
Could you explain to me ?
Thanks.
________________
Attachments :
SurveyReport_1_.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0NN&d=%2Fa%2F0X0000000bYB%2FtvrzSGr90DQVqPhQkGMGrsZvO6yOLLIcfMH6M0XAeCg&asPdf=false
fabien2
If I do understand this time the references has changed
In the past the ST 10 R 167 was different
because the block diagram I possess puts to light an internal rom
and it's not the case any more. So the generic family ST 10 X makes now a difference with the last generation of chips.
Is it all right if I replace now an OLD ST10R167 by a NEW ST10C167 ?
And what would be the software to be used for programming it ?
