2004-11-25 07:30 PM
2004-11-25 12:39 AM
I need a list of the instructions with the number of cylces needed to compute that instruction. I couln't find that on the web.
We use: st72321 Where can I get this list? Regards Bastian2004-11-25 01:29 AM
In Visual Debug/Develop goto Help/Help On Instruction menu item.
Each instruction is given a number of cycles required. This information is also calculated in the simulator, View/ST7 Register have a look at the Time and Instruction counter tabs. Regards sjo2004-11-25 02:01 AM
Pls download ''ST7 Family Programming Manual'' from the same site.
It explains all instructions and addressing modes etc.2004-11-25 02:14 AM
Hi Bastian,
you can take the PDF-file of the There you find a complete description of each ST7 instruction beginning on page 33, including the number of cycles -cy-. Regards WoRo2004-11-25 07:30 PM
Thanks for that! Now I found what I was searching for.
Regards Bastian
